Topic "Fail to open a connection"
EddieL
I am using the .NET library and I followed the exact same steps described in the code sample that is available here. Even though I use the correct parameters for the host name, user name, password, and SSH host key, the authentication fails and the connection is not open. Is there a way to troubleshoot this issue, eventually to find out what else is missing?
TIA,
Eddie
EddieL
TIA,
Eddie
I must mention that the WinSCP client fails too. I get an access denied response. However, I can connect with the same credentials using a web client available over HTTPS that is exposed from the server.
Can you connect with any other SSH client?
EddieL
Yes, sorry, I should have announced here that I solved the problem. What happened is that my account was locked out because of my several attempts to login with a wrong user name/password combination. Once the account was fixed, I could connect without any issues.
Thanks for getting back to me.
All the best,
Eddie
