Topic "period character in remote path"
Rylan
On my remote server, I can access the same location at both of the following paths.
/test/.myfolder/
/test/myfolder/
I don't know much about this server, I'm not an admin, just need to automate file uploads.
When I try uploading files to /test/myfolder/ I will occasionally get the following error.
Real path and requested remote path do not match:
"/test/.myfolder/"
"/test/myfolder/"
So I try uploading files to /test/.myfolder/ and again I will occasionally get the same error.
I've tried to isolate what causes the error but with no luck. The error occurs randomly as far as I can tell. It doesn't matter if I include the period in the remote path or not. It works sometimes with both paths, and it fails sometimes with both paths.
Could this be a bug or limitation in winscp or is there something funky happening on my remote server?
Can you attach a log file for both scenarios (success and failure)?
Rylan
Logs Attached.
The key lines I noticed.
With period in remote path (success)
> 2014-08-21 09:23:15.061 CWD /test/.myfolder/
< 2014-08-21 09:23:15.088 250 CWD command successful.
> 2014-08-21 09:23:15.088 PWD
< 2014-08-21 09:23:15.117 257 "/test/.myfolder" is current directory.
With period in remote path (failure)
> 2014-08-21 09:26:34.852 CWD /test/.myfolder/
< 2014-08-21 09:26:34.878 250 CWD command successful.
> 2014-08-21 09:26:34.878 PWD
< 2014-08-21 09:26:34.907 257 "/test/myfolder" is current directory.
. 2014-08-21 09:26:34.907 Real path and requested remote path do not match: "/test/myfolder/" "/test/.myfolder/"
Without period in remote path (success)
> 2014-08-21 09:25:03.109 CWD /test/myfolder/
< 2014-08-21 09:25:03.141 250 CWD command successful.
> 2014-08-21 09:25:03.141 PWD
< 2014-08-21 09:25:03.171 257 "/test/myfolder" is current directory.
Without period in remote path (failure)
> 2014-08-21 09:28:53.717 CWD /test/myfolder/
< 2014-08-21 09:28:53.743 250 CWD command successful.
> 2014-08-21 09:28:53.743 PWD
< 2014-08-21 09:28:53.774 257 "/test/.myfolder" is current directory.
. 2014-08-21 09:28:53.774 Real path and requested remote path do not match: "/test/.myfolder/" "/test/myfolder/"
Thank you for the help!
logs.txt (24.92 KB) [Download]
Description: Logs
Thanks for the logs.
Well, as you can see yourself, the server behaves rather erratically. I'm not sure what I can do about it.
Rylan
Okay, thanks for looking. I coded to retry on the alternative path if the initial attempt fails and have had zero issues. Is strange but at least it works.
