Topic "How to use custom command to zip a folder?"
Akari
I know how to zip a file with
zip -r "!?&File(&A):?archive.zip!" !&
and i know how to zip a folder with
zip -r "!?File(&A):?archive.zip!" !& "!?Folder(&A):?folder name!" !&
But is there a way to zip a select folder without typing any archive name or folder name?
e.g if i selected folder name abc once i rune the command it will create a zip file name abc.zip
I do not understand your "ZIP folder" command. It seems wrong.
Anyway to ZIP selected folder, use zip -r "!.zip" "!". This way you cannot pack more folders into one archive.
Akari
Not working for me,
Is there anything require by the server?
But i tried
 zip -r "a!.zip" "!/"
in folder /WWW/abc/
and i selected 123 folder, the output is zip the /WWW/abc/ in a.zip file.
Akari wrote:
Not working for me
That's not very helpful statement. What does it do? Any error message?
Did you check the Apply to directories option?
Akari
Thank you,prikryl!
I just notice i din't check the box "Apply to directories",
after check it, the command is working!! That y alot of command dint run for me..
Sorry my bad english, and thank for your patient to solve my problem. You help me alot, thank again!
higgins
The gzip command won't recursively clamp a catalog into a solitary compress record, when utilizing the -r switch. Rather it will walk that registry structure and compress each one document that it finds into a different record.
MGM
How to add timestamp to zip archive?
Like: folder ==> zip into ==> folder-timestamp.zip
zip -r "!-`date +%Y%m%d%H%M`.zip" "!/"
