Topic "How to track when a file is fail to transfer?"
huahsin68
According to the sample code in C# from this link > http://winscp.net/eng/docs/library#csharp, there is a piece that tracking whether the file is successfully transfer. As shown here:
// Print results
foreach (TransferEventArgs transfer in transferResult.Transfers)
    Console.WriteLine("Upload of {0} succeeded", transfer.FileName);
I did some experiment on this code, I found out that this code unable to track when the file was fail to transfer. May I know how could I track when a file is failed to transfer?
No. The code that checks if there is any failure is transferResult.Check();. Alternatively check TransferOperationResult.Failures.
See http://winscp.net/eng/docs/library_session#results
huahsin68
Can I perform the check using the following code?
TransferOperationResult tor = session.PutFiles(...);
tor.Check();
if( tor.Transfers.Count > 0 )
   // suscess
else
   // fail
I just test on the code and it works. But I wasn't sure whether this is the right way of checking?
If there's a failure, the tor.Check() throws. So should actually never get to the // fail branch (unless you selected no files for transfer, but than it's not a failure). On the other hand the tor.Transfers.Count > 0 is not an indication of success, but possibly of a partial success only. But again, mere fact that tor.Check() did not throw is an indication of success.
