Topic "Sorting"
Dion
Sort by Type use to Sort Type and Name. It seems anything after 5.5.3 only sorts Type and puts files out of alphabetical order.
Hope this can be fixed.
There was indeed a change to remote Type column sorting in 5.5.4:
http://winscp.net/tracker/show_bug.cgi?id=1158
It now sorts by Type, Extension and Name. In most cases the change should have no effect as typically files with same Type have the same Extension.
Dion
Here is 2 SS's showing the issue I am having.
https://someimage.com/U5IWCdz - Fixed
https://someimage.com/R6hsVNo - Broken
OK, I see.
http://winscp.net/tracker/show_bug.cgi?id=1211
Can you send me an email, so I can send you back a development version of WinSCP for testing? Please include link back to this topic in your email. Also note in this topic that you have sent the email. Thanks.
Dion
Email has been sent...
