Topic "Automatic backup remote FTP with timestamp script"
Guest_DK
I would like to have created ​​a batch script that automatically backs up my website files using FTP protocol. Website files are located on remote FTP servers. I want that every time the backup script is run, then the files are saved in a folder with a timestamp.
Like this:
C:\Backups\Webpage_1_DDMMYYYY
C:\Backups\Webpage_2_DDMMYYYY
I have so far been created the following:
# Automatically abort script on errors
option batch on
# Connect
open username@serverhost
# Change remote directory
cd /webpage1
# Force binary mode transfer
option transfer binary
# Download file to the local directory C:\Backups
get /webpage1* C:\Backups\webpage1*
get /webpage2* C:\Backups\webpage2*
# Disconnect
close
# Exit WinSCP
How can I add timestamp to the backup folders?
I want to create the script in batch (BAT) instead of PowerShell because the WinSCP NET Assembly and COM Library requires .Net Framework v3.5/4.0 and I do not want to install this on my Windows Server.
Thanks in advance.
See http://winscp.net/eng/docs/script_download_timestamped_filename#using_winscp_scripting
