Topic "Use the same server list for all users"
hias116
How can I use the list with the FTP- and SFTP-accounts for all users at one pc?
Thank You!!
Regards
Matthias
Some ssh user
Using Windows 7 you can create symbolic link:
Move your ini file to: C:\WinSCP.ini
And then type in console for every user (just you have to change {USER_NAME}):
mklink C:\Users\{USER_NAME}\AppData\Roaming\WinSCP.ini C:\WinSCP.ini
If you don't have ini file: Preferences -> Storage -> Configuration storage: change to INI file
Good luck!
You can avoid creating symbolic links by creating an all-users desktop shortcut with /ini=C:\WinSCP.ini command-line parameter.
See http://winscp.net/eng/docs/config
