synchronize locally any directory with remote directory
Leoninono
Hi there,
It is the first time I use winscp, and I am a rookie. I'm trying to run the process as indicated in the help guide called "Shortcut to synchronize locally any directory with remote directory", but do not understand the section that says "First create wrapper batch file to store the paths you want to synchronize into environment variables".
How and where you create this batch file?
Could you show me an example as shown in this help section ??
And it would be possible to use this batch file wrapper in .NET Assembly ??
Examples:
For C #
This:
SynchronizationMode.Remote, @"d:\www","/home/martin/public_html ", false);
For this:
SynchronizationMode.Remote,wrapper batch file, false);
(I Do not know if the syntax is correct)
Or to VB.Net
This:
SynchronizationMode.Remote, "d:\​​www","/home/martin/public_html",False)
For this:
SynchronizationMode.Remote, wrapper batch file, False)
(I do not know if the syntax is correct)
Thank you !!!
Re: synchronize locally any directory with remote directory
You can create it using any text file editor, e.g. Notepad. Save it to any folder you want, e.g. you document folder.
It does not make sense. Maybe you mean if you can call the assembly from the batch file and pass the path. You can, e.g. using PowerShell.
