Topic "Moving files with time constraint"
rsmallwood
For some reason I can't get the time constraint to work.
This is what I had before (which works fine):
mv iVUpload*.xml archive/
This, however, does not:
mv iVUpload*.xml<2D archive/
It is supposed to move files into the archive folder if they are more than 2 days old.
Anyone know why it doesn't work?
Many thanks
Robin
Works for me.
Can you be more specific about the problem? Does it fail? Moves all files? Moves no files?
rsmallwood
Well, I had three files:
File 1: modified date of 'yesterday'
File 2: modified date of 3 days ago
File 3 modified date of 4 days ago
None of the files were moved. I was expecting files 2 & 3 to be moved.
Log attached.
prikryl wrote:
Works for me.
WinSCP Log.txt (3.15 KB) [Download]
Description: (none)
rsmallwood wrote:
Log attached.
Well, you are using over 5 years old version of WinSCP. It's quite likely that it does not support time-constraints with mvcommand. Please upgrade and try again.
