Topic "Webdav Gui works, but .NET COM library fails with error 400"
GregH
So I opened a session with the gui ... works great!!! good work! but when I try it with the .net library (in powershell) I get a 400 error bad request with the same sessionOptions as the gui session.
I've tried a bunch of permutations of the hostname, including the username and the starting directory. But no luck.
Any idea why this would be?
using non-secure webdav, with hostname, password and username set.
log.txt (19.63 KB) Private file
Description: (none)
Session.SessionLogPath please, not Session.DebugLogPath.
Also s session log file from GUI session would help too.
GregH
Sorry about that, thanks for the help
guilog.txt (1.29 MB) [Download]
Description: (none)
sessionlog.txt (4.25 KB) [Download]
Description: (none)
Thanks for the logs.
http://winscp.net/tracker/show_bug.cgi?id=1213
I'm sending you an email with a development version of WinSCP to address you have used to register on this forum.
