Topic "Powershell Script to SFTP New files"
I have a script here that SFTP's files from one location to another, the script works fine however I'd like to change the script so that it only copies files that are not already present. Bit of a newb with powershell so any help would be greatly appreciated.
cd "c:\Program Files (x86)\WinSCP\" # location of .NET assembly ddl file
# Load WinSCP .NET assembly
Add-Type -Path "WinSCPnet.dll"
# Setup session options
$sessionOptions.Protocol = [WinSCP.Protocol]::Sftp
$sessionOptions.HostName = ""
$sessionOptions.UserName = "xxxx"
$sessionOptions.Password = "xxxx"
$sessionOptions.SshHostKeyFingerprint = "ssh-rsa 2048 xx:xx:xx"
# Connect
$stamp = Get-Date -f "yyyyMMdd"
$fileName = "export_$stamp.txt"
$remotePath = "/home/user/john/reports"
$localPath = "\\fileserver\reports\"
if ($session.FileExists($remotePath))
if (!(Test-Path $localPath))
Write-Host (
"File {0} exists, local backup {1} does not" -f
$remotePath, $localPath)
$download = $True
if ($download)
# Download the file and throw on any error
$session.GetFiles($remotePath, $localPath).Check()
Write-Host "Download to backup done."
Write-Host ("File {0} does not exist yet" -f $remotePath)
# Disconnect, clean up
exit 0
catch [Exception]
Write-Host $_.Exception.Message
exit 1
See my answer to your duplicate question on
The script your took from WinSCP example for Session.GetFiles was designed for a single file only. You have tried to bend it to synchronize directories instead. That cannot work.
To synchronize directories, use Session.SynchronizeDirectories:
# Synchronize files
$synchronizationResult = $session.SynchronizeDirectories(
    [WinSCP.SynchronizationMode]::Local, $localPath $remotePath)
# Throw on any error
