Topic "Getting "syntax error, unrecognized command" error"
deepak chhetri
I have connected to a server using FTP connection using port 21 in WinSCP utility from Windows machine.
When I try to upload a zip file of around 400 MB into the server using ftp connection using drag and drop, then following error is thrown:
"Failed to copy file in remote macine.
Syntax error, command unrecognized."
I tried to search for the solution on various forum, but could not find it.
Any help is appreciated in advance.
kasfulanwar
I have a same problem this is my server log file
I hope you can help..
Thanks..
filezilla log.txt (1.95 KB) Private file
Description: filezilla server log file
Are you using WinSCP? It does not look like you are.
