Topic "Can't get scheduled task to synchronize successfully"
jeff.a.toy
See also http://winscp.net/eng/docs/message_preserve_time_perm
jeff.a.toy
Actually, using "Keep remote directory up to date" will work better than a scheduled task since I want the files automatically transferred to the SFTP server when they are added to the local directory. However, the same error happens when I click "Start" to synchronize. Even when I select "Ignore permission errors." Suggestions?
jeff.a.toy
I think this might have something to do with my timestamps on my local server not being UTC. I read that "With SFTP and FTP2) protocols, both client and server need to use UTC timestamps." Since it is not an option changing my server timestamp to UTC, I believe I need to uncheck "preserve timestamps." However, that option is greyed out. Why would it be greyed out?
I do not understand this thread. Is there something missing? You refer to some error, but I do not know what. Did you want to attach a log file?
