Topic "FTP: Unable to access specified folder name (download)"
Richard Wong
I had trouble downloading files using winscp vers, and The error i get are :
Can't get attributes of file '......csv'-->WInSCP.SessionRemoteException: File or Folder '.....csv' does not exist.
I am running FTP protocol. the remote path I set to \Uploads\ it seems that I can't specify the folder from the remote path when using FTP, but I can do it in SFTP. Is there any solutions to this? or the WinSCPnet.dll and exe behaves this way?
Also, can you try 5.6.1 beta?
