Topic "Cannot rename files/folders error 301 Moved Permanently"
PaulaG
I am using winDrag&drop shell extension use is enabled, but the extension is not installed. Install the extension or switch to compatible drag&drop mode (from Preferences window), which uses temporary folder for downloads." - I fixed it in Preferences so I don't get this particular message when I try to drag&drop, but then get the message below... Also installed extension.
"WebDAV resource moved to 'https://........."
301 Moved Permanently" - caused by trying to rename folder on drive
PaulaG
Thank you. I am attaching log file here.
Let me know what suggestions or comments you have.
much appreciated.
Paula
301error..log.log (323.3 KB) Private file
Description: (none)
http://winscp.net/tracker/show_bug.cgi?id=1229
PaulaG
Yes, that fixed that bug (Log will be included) -- I can now successfully rename files and folders.
Will this new zipped copy work for other users here if I give them the new WinSCP copy?
I do have a new problem though I just noticed, as such:
Once I have connected, if I try to Drag and Drop a file from the Winscp webdav interface to my desktop, the file disappears from the webdav share.
If I select the same file and Download using the 'Download' toolbar button, the behavior is as expected; meaning it copies the file to my desktop as well as leaving it in place on the connected webdav share. I checked the Tools > Preferences > Drag and Drop menu and I think I have it right: Checked "Allow moving from remote directory to other applications" and selected "Use Shell extension"
This new problem is also in same log as I will submit to forum in my reply.
thank you for your help.
newlog.log (163.75 KB) Private file
Description: (none)
Did you read this?
http://winscp.net/eng/docs/faq_drag_move
