Topic "Net assembly working in background thread"
kaheiho
Please apologize me if this is a n00bie question! I have searched this site but didn´t get it.
We use WinScp within a .NET assembly to download regularily many groups of files from ftp-server. In each group is one textfile (small) and two files containing (big) images. We would download the textfiles first and the images in a separate background-thread, because the textfiles contain informations to do further work with the corresponding images of the respective group. This further work should be done while the images are being transferred in the separate background-thread.
We tried to start WinScp like this:
workThread = New Thread(New ThreadStart(AddressOf MoveImages))
workThread.Priority = ThreadPriority.AboveNormal
workThread.Start()
Function MoveImages works well, but if its executed in workThread nothing is downloaded. How can we reach our goal?
And how could we get information about exitcodes WinSCP in this workthread?
And last but not least: the amount of your support is impressing!!! Very Happy
Many thanks for your posts!
kaheiho
kaheiho
Thank you for your fast reply - I wonder where you take the time!
In our program we have two routines using WinSCP: the first one to be processed dir-lists only the upload-directory of the ftp-server and produces a logfile "WinSCP_GetFtpDirList...log" - see its output in the zipfile, all works well. The second one should download the big images, which is time consuming and therefore should work in the background. With SessinLogPath set I realized, that execution of the routine breaks at line 24 "session.Open(sessionOptions)" - please see attached code "MoveFtpFilesToImpDir.vb" and "MoveFtpFilesToImpDir_20141003-2013.log" in the zipfile.
Many thanks in advance for your advice and best regards!
kaheiho
MoveFtpFiles.zip (8.63 KB) Private file
Description: containes files mentioned above
