Topic "Using /upload command line option."
Jaime
Hi all,
Is there any option to avoid the window that asks for the confirmation to copy a file when using the upload command line option ??
The option /upload is very usefull to automate uploading files, but if you must be there clicking the OK button its no so usefull.
Thanks a lot.
Question Question
mpreishu
Jaime wrote:
Hi all,
Thanks a lot.
Question Question
I have exactly the same problem. Reading the FAQ it says to use some commanline scp client (e.g. PSCP), which is not possible on my side, because I need socks proxy support, so /upload with just doing the upload and quit would be perfect.
Regards,
Martin
Full scripting/automation will be included in the next major version.
The /upload switch is there only to support Windows "Send to" menu, not for automation.
For automation please read FAQ.
