Topic "WinSCP hangs @ Looking up host"
MikeN
I have a SQL job that uploads some TXT files to a remote sever nightly using WinSCP. The job runs fine when I manually run it but when it is scheduled it does not complete properly, nor does it provide an accurate error message. I'm not sure if it's a remote host problem or a local user rights issue.
Windows Server 2008 R2
MS SQL Server 2008 R2
WinSCP 5.5.5.4605
The BAT file that runs the job:
d:
cd \MILLHTML\online~1\export
echo ********** Start Export ********** >> export.log
date /T >> export.log
time /T >> export.log
copy *.txt .\savefile\
echo ********** Initiating SFTP Transfer ********** >> export.log
psftp -v -pw <<password>> <<user>>@ssh.<<host>>.com -b sshtransfer.ftp >>export.log
echo ********** SFTP Transfer Complete ********** >> export.log
erase *.txt
echo ********** End Export ********** >> export.log
The sshtransfer.ftp command:
mput *.txt
quit
The Log:
Tue 10/07/2014
05:30 PM
. 2014-10-07 17:30:09.284 --------------------------------------------------------------------------
. 2014-10-07 17:30:09.284 WinSCP Version 5.5.5 (Build 4605) (OS 6.1.7601 Service Pack 1 - Windows Server 2008 R2 Standard)
. 2014-10-07 17:30:09.284 Configuration: D:\MILLHTML\ONLINE~1\export\WinSCP.ini
. 2014-10-07 17:30:09.284 Local account: FND\SQLUser
. 2014-10-07 17:30:09.284 Working directory: D:\MILLHTML\ONLINE~1\export
. 2014-10-07 17:30:09.284 Process ID: 2696
. 2014-10-07 17:30:09.284 Command-line: "D:\MILLHTML\ONLINE~1\export\WinSCP.exe" /console=555 /consoleinstance=_4884_670 "/console" "/script=WinSCP.ftp" "/log=WinSCPexportPCI.log"
. 2014-10-07 17:30:09.284 Time zone: Current: GMT-4, Standard: GMT-5 (Eastern Standard Time), DST: GMT-4 (Eastern Daylight Time), DST Start: 3/9/2014, DST End: 11/2/2014
. 2014-10-07 17:30:09.284 Login time: Tuesday, October 07, 2014 5:30:09 PM
. 2014-10-07 17:30:09.284 Script: Retrospectively logging previous script records:
> 2014-10-07 17:30:09.284 Script: option batch abort
< 2014-10-07 17:30:09.284 Script: batch abort
> 2014-10-07 17:30:09.284 Script: option confirm off
< 2014-10-07 17:30:09.284 Script: confirm off
> 2014-10-07 17:30:09.284 Script: option transfer binary
< 2014-10-07 17:30:09.284 Script: transfer binary
> 2014-10-07 17:30:09.284 Script: open <<user>>:***@ssh.<<host>>.com:22
. 2014-10-07 17:30:09.284 Session name: <<user>>@ssh.<<host>>.com (Ad-Hoc site)
. 2014-10-07 17:30:09.284 Host name: ssh.<<host>>.com (Port: 22)
. 2014-10-07 17:30:09.284 User name: <<user>> (Password: Yes, Key file: No)
. 2014-10-07 17:30:09.284 Tunnel: No
. 2014-10-07 17:30:09.284 Transfer Protocol: SFTP (SCP)
. 2014-10-07 17:30:09.284 Ping type: -, Ping interval: 30 sec; Timeout: 15 sec
. 2014-10-07 17:30:09.284 Proxy: none
. 2014-10-07 17:30:09.284 Send buffer: 262144
. 2014-10-07 17:30:09.284 SSH protocol version: 2; Compression: No
. 2014-10-07 17:30:09.284 Bypass authentication: No
. 2014-10-07 17:30:09.284 Try agent: Yes; Agent forwarding: No; TIS/CryptoCard: No; KI: Yes; GSSAPI: No
. 2014-10-07 17:30:09.284 Ciphers: aes,blowfish,3des,WARN,arcfour,des; Ssh2DES: No
. 2014-10-07 17:30:09.284 SSH Bugs: A,A,A,A,A,A,A,A,A,A
. 2014-10-07 17:30:09.284 Simple channel: Yes
. 2014-10-07 17:30:09.284 Return code variable: Autodetect; Lookup user groups: A
. 2014-10-07 17:30:09.284 Shell: default
. 2014-10-07 17:30:09.284 EOL: 0, UTF: 2
. 2014-10-07 17:30:09.284 Clear aliases: Yes, Unset nat.vars: Yes, Resolve symlinks: Yes
. 2014-10-07 17:30:09.284 LS: ls -la, Ign LS warn: Yes, Scp1 Comp: No
. 2014-10-07 17:30:09.284 SFTP Bugs: A,A
. 2014-10-07 17:30:09.284 SFTP Server: default
. 2014-10-07 17:30:09.284 Local directory: default, Remote directory: home, Update: Yes, Cache: Yes
. 2014-10-07 17:30:09.284 Cache directory changes: Yes, Permanent: Yes
. 2014-10-07 17:30:09.284 DST mode: 1; Timezone offset: 0h 0m
. 2014-10-07 17:30:09.284 Looking up host "ssh.<<host>>.com"
Tue 10/07/2014
05:30 PM
Tue 10/07/2014
05:30 PM
After the Looking up host "ssh.<<host>>.com" is should then connect. I don't know why is doesn't connect and continue or at least provide me with an error message, something..
I'd expect that your scheduler's account group policy restricts network connections.
Hi prikryl, I'm not sure I understand you response, I'd expect that your scheduler's account group policy restricts network connections. I can logon as or run the .bat file as SQLUser and the upload functions perfectly. Can you provide more detail on your response? Thanks in advance.
MikeN
It seems that my issue was resolved by editing the compatibility of the WinSCP.exe and enabling the 'Run this program as an administrator' setting.
That would confirm my assumption that the problem is about permissions.
