Topic "vb6 COM libary"
I installed the COM library and I can see it in the object browser in VB6, but many of the classes have nothing in them, like session. Further when I try to store & then retrieve session variables like in the demo the application crashes. I need to use VB6 I think for fixing a legacy program, so what I want to know is, is it possible to use the COM library in VB6? Am I missing something?
Here is some code. I know it's getting to the sub because the first MsgBox is firing.
Private session As WinSCPnet.session
Private Sub SendWinSCP()
MsgBox ("in SendWinSCP")
Set sessionOptions = New WinSCPnet.sessionOptions
sessionOptions.HostName = ""
MsgBox ("in SendWinSCP4 " & sessionOptions.HostName & "!")
' at this point it crashes since HostName can not be found.
I do not have VB6 to test this myself. But WinSCP .NET assembly works correctly in VBA, so I hope that it works in VB6 too.
It works fine, I needed to add "On Error Resume Next". Most of the classes are indeed hidden but work fine.
I was able to use the VBA code and send a file via SFTP using VB6.
