Topic "pseudo-tty option available in WinSCP?"
harkman
Hello.
Unix ssh client has a option to create a pseudo-tty when establishing a new connection ( ssh -t).
Can this be done with WinSCP too?
Background:
We use a CentOS 6 and have blocked root login with SSH
I try to setup the login with WinSCP with a unprivileged user and the doing sodo like described here: http://winscp.net/eng/docs/faq_su
Problem now is that winscp cannot establish a connection because sudo is only allowed if a proper shell is created. Sudo configuration explains:
# Disable "ssh hostname sudo <cmd>", because it will show the password in clear.
#         You have to run "ssh -t hostname sudo <cmd>".
Defaults    requiretty
As I really do not want to expose any passwords I'd like to keep the sudo config this way.
You cannot use requiretty with WinSCP.
See http://winscp.net/eng/docs/faq_su
Skeeve
Maybe this is a valid workaround for you? http://winscp.net/forum/viewtopic.php?t=14441
harkman
@Skeeve: Thanks for the link. I will try this eventually. For now we switched to public key based authorisation and disabled password auth. I think this way we can disable "requiretty" without breaching security.
Skeeve
Publickey is better for ssh anyway. For sudo, if you can live without the additional password - great. In my environment I can't switch it off. That's why I had to find a workaround.
