Topic "Disconnects during download"
NickHark
Greetings!
New user. Win7 Ultimate. ADSL.
I am temporarily in France and want to use WinSCP to download files from my Readynas NV+1 located in San Jose, California.
I use the gui, SCP format.
It seems to time out frequently. I was able to download only one complete file [400 MBs] after numerous tries.
I can successfully use AndFTP using SCP, on my smartphone.
I've tried it with Optimize buffers off; do not try FTP if disconnect; server timeout 300 seconds; keep alive 30 seconds; time zone -9 hours and resend key 0.
When it fails the progress column says "query" and then I get an error message download fatally failed.
Can you help me troubleshoot this?
Attached is my log.
Cleaned WinSCP.zip (7.29 KB) Private file
Description: (none)
I do not see any download in the log.
NickHark
I deleted the attachment and re posted a log.
Sorry for my ignorance, I am not sure what I need to remove from the log to make sure my system cannot be accessed.
Here is an updated post with a current UL log.
WinSCP v5.5.6
Win7 64b Ultimate
Using Commander Interface
I am temporarily in France and want to use WinSCP to download and upload files from my Readynas NV+1.
SFTP seems to work better than SCP.
I can successfully use AndFTP using SCP.
I am installing the latest MS updates, everyday its more.
Attached is my log. I set it to private.
UL-Photos094531 cleaned.zip (845.36 KB) Private file
Description: (none)
Thanks for the log. Can AndFTP log too?
