Topic "Speed difference"
sunrisecc
I uploaded 3773 files to my server using the latest WinSCP via FTP explicit over TLS. It took over 45 minutes. I did see under the Progress column the status of 'connecting' very often.
I then tried the same files using the same method via Filezilla and it took 15 minutes.
What options can I change in WinSCP?
I am running Win 7 - 32 bit.
Seymour
sunrisecc
A further update.
If I delete the files uploaded via WinSCP, the connection drops every so often. However with Filezilla, it never drops.
Seymour
Please attach complete log files both from WinSCP and FileZilla.
sunrisecc
I will shorten the list of files and generate both logs some time today.
Seymour
sunrisecc
I am attaching three logs, Filezilla and two foe WinSCP. The first is the default log for the upload and delete of the same files. The second is under the option of debug 1.
Seymour
winscp.zip (760.02 KB) Private file
Description: see above
Thanks for the logs. Though the FileZilla log shows only the upload, not the delete.
sunrisecc
That is correct. I should have been clearer. Only the first WinSCP log has the delete in it. Shortly I will generate a log for the Filezilla delete.
Seymour
sunrisecc
New Filezilla upload and delete log.
Seymour
filezilla1022.zip (184.77 KB) Private file
Description: (none)
sunrisecc
I received a notice that this topic was updated, Yet it is nowhere to be found.
What happened?
Seymour
Actually I do not see any disconnects in the WinSCP log.
WinSCP is indeed slower as it uses only one connection for the upload. As you are uploading several folders, you can save some time by checking Transfer each file individually :
http://winscp.net/eng/docs/ui_copy
Further improvement to this is pending:
http://winscp.net/tracker/show_bug.cgi?id=875
For the delete part, WinSCP is actually faster then FileZilla.
sunrisecc
I will add that option and test again later today and then report back either way.
Seymour
sunrisecc
Adding the option requested dropped the transfer time from 45 minutes to 20.
Thank you.
Seymour
Thanks for your feedback.
