Topic "WinSCP 5.6.2 beta .NET assembly raw commands broken"
GieltjE
Setting any rawcommand using the 5.6.2 beta using SFTP with public key authentication release gives an exception, this used to work just fine with 5.6.1
WinSCP.SessionRemoteException: Host "SshProt=3" does not exist.
   at WinSCP.SessionLogReader.Read(LogReadFlags flags)
   at WinSCP.ElementLogReader.Read(LogReadFlags flags)
   at WinSCP.SessionElementLogReader.Read(LogReadFlags flags)
   at WinSCP.CustomLogReader.TryWaitForNonEmptyElement(String localName, LogReadFlags flags)
   at WinSCP.Session.Open(SessionOptions sessionOptions)
   at Extends.Functions.Server.Sftp.OpenSession(String writeableTestDirectory, String host, String user, String fingerprint)
http://winscp.net/tracker/show_bug.cgi?id=1234
I'm sending you an email with a dev version of WinSCP to address you have used to register on this forum.
GieltjE
The beta version performs like it should, many thanks for the quick fix!
