Topic "Exporting deleted session / import disapers after logging in"
knappmk
I think I found a bug while using the export/import-functionality of WinSCP.
When you delete a Session in login/session-window (when you start WinSCP), it isn't displayed anymore. But when you export your settings to an ini-file, the deleted sessions and folders where still inside the ini-file. That's also the reason, why deleted sessions and folders appear again when restoring the ini-file.
Another strange thing is, when you start WinSCP it is possible to import settings from an ini-file. After you logged into a session and colsed it again (Session > Session disconnect), there were less options (such as import settings...) under the button 'tools' in the login/session-window. When restarting the application the dissapeared options appear again.
I hope I discribed the problems well enough.
Greetings,
knappmk
[Sorry for my bad English]
I cannot reproduce the problem.
These additional tools are indeed available on initial Login window only.
Documented here: http://winscp.net/eng/docs/ui_login#tools
knappmk
prikryl wrote:
Also note in this topic that you have sent the email.
I've send an email to prikryl.
There is a more detailed description in the email about the problem when exporting the settings and sessions. The problem described above only appears when the ini-file is overwritten while using the export-function.
http://winscp.net/tracker/show_bug.cgi?id=1300
