Session.SynchronizeDirectories code example in VBA\VB6?
Rock28
USA
First of all, thank you very much to the author of WinSCP for this amazing software!
I'm using VB6 on 32-bit WinXP. WinSCPnet.dll has been registered, is listed in Project > References, and is checked. WinSCP is installed, tested, and working fine as a standalone program. What I'm trying to do is implement the SynchronizeDirectories.Remote functionality of WinSCP into the code that I'm writing that updates and deletes frequently-changing groups of files from local to my server.
The following code is exactly what I need, except its in VB.NET and I've been trying without success to translate it to VB6:
https://winscp.net/eng/docs/library_session_synchronizedirectories#vbnet
I just don't understand VB.NET enough to be able to translate all the code in the example to VB6. Can someone please post a full translation?
thom321
Re: Session.SynchronizeDirectories code example in VBA\VB6?
Using the examples from the documentation, this code works, although it needs more result/error checking since it currently only checks uploads.
I was testing using FTP but I kept the original SFTP code (as a reminder to add more flexibility to the code) and skip over it using Goto. Obviously remove/edit this based on your setup.
Keep in mind that Session.SynchronizeDirectories has more options and I am implicitly using the defaults when not specified.
Code for VBA:
Sub SyncExample()
    Dim mySession As New Session
    ' Enable custom error handling
    On Error Resume Next
    SynchronizeDirectoryTest mySession
    ' Query for errors
    If Err.Number <> 0 Then
        MsgBox "Error: " & Err.Description
        ' Clear the error
        Err.Clear
    End If
    ' Disconnect, clean up
    mySession.Dispose
    ' Restore default error handling
    On Error GoTo 0
End Sub
Private Sub SynchronizeDirectoryTest(ByRef mySession As Session)
    ' Setup session options
    Dim mySessionOptions As New SessionOptions
    Dim sLocalPath as string
    Dim sRemotePath as string
    sLocalPath = "C:\Temp"
    sRemotePath = "example.com/test"
    GoTo FTPlogin 'remove this if you want to use Sftp.
    With mySessionOptions
        .Protocol = Protocol_Sftp
        .HostName = "example.com"
        .UserName = "user"
        .Password = "mypassword"
        .SshHostKeyFingerprint = "ssh-rsa 2048 xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx"
    End With
FTPlogin:
       .Protocol = Protocol_Ftp
       .UserName = "user"
       .Password = "password"
    End With
    ' Connect
    mySession.Open mySessionOptions
    Dim mySynchronizationResult As SynchronizationResult
    Set mySynchronizationResult = mySession.SynchronizeDirectories(SynchronizationMode.SynchronizationMode_Remote, sLocalPath, sRemotePath, False)
    ' Throw on any error
    mySynchronizationResult.check
    ' Display results
    Dim transfer As TransferEventArgs
    For Each transfer In mySynchronizationResult.Uploads
        MsgBox "Upload of " & transfer.FileName & " succeeded"
    Next
End Sub
bfuchs
Permission denied error
Hi I'm getting an error permission denied on the following
Set transferResult = _
    mySession.SynchronizeDirectories( _
        SynchronizationMode.SynchronizationMode_Local, _
        "H:\FTP\", "/Outbox/*", 0, 0, _
        SynchronizationCriteria.SynchronizationCriteria_Time, _
        myTransferOptions)
Any idea how to fix that?
