Topic "FileExists says file exists even when it does not"
Karen Healey
I am using the latest WinSCP, just downloaded today on Windows 7. I copied your VB example
http://winscp.net/eng/docs/library_session_getfiles#example
The line : If mySession.FileExists(remotePath) Then
always returns true, even though the file does not exist. Then, it "gets" an empty file. Session log is attached.
What am I doing wrong?
Thank you,
Karen Healey
As you can see in the log, your server provides information (possibly fake) for the file /infiles/dhcdheat/export20141103.txt as if it existed.
Quote:
> 2014-11-03 16:25:43.869 Script: stat -- "/infiles/dhcdheat/export20141103.txt"
. 2014-11-03 16:25:43.869 Listing file "/infiles/dhcdheat/export20141103.txt".
> 2014-11-03 16:25:43.869 Type: SSH_FXP_LSTAT, Size: 45, Number: 263
< 2014-11-03 16:25:43.884 Type: SSH_FXP_ATTRS, Size: 13, Number: 263
. 2014-11-03 16:25:43.884 export20141103.txt;-;0;1899-12-30T05:00:00.000Z;"" [0];"" [0];r-xr-xr-x;0
< 2014-11-03 16:25:43.884 Script: -r-xr-xr-x 0 0 Dec 30 0:00:00 1899 export20141103.txt
If the file does not exist, it's a server-side bug.
Oh.. thanks! The file definitely does not exist because I was deliberately testing that scenario. I'm not sure why the server is reporting that it does exist. That is very strange.
I'll find a work around.
Thank you,
Karen Healey
Why would the server say that a file exists when it doesn't? Is this possibly a response from a non-Windows server?
Karen Healey
In addition, GetFileInfo is returning invalid information even when the file exists. I wanted to check for a length of 0 but even files that exist have a length of 0 according to GetFileInfo. Clearly, the server is returning invalid information, but the question remains, Why?
Karen Healey
No idea. What is your server? I didn't checked before removing the log file.
