Topic "Issues with WinSCP - Authenticating SFTP connection ppk"
bsudhir6
I have a private key file to access an FTP host. I am trying to add private key file to Authentication I am getting following error:
'Key file' does not exists or it does not contain private key in known format.
When I tried the same from PuTTY i was able to connect to SSH Console without issues. Since I need an FTP client for file processing but not an SSH client.
Please advice how can I resolve this issue.
bsudhir6
I noticed that I had older version of WinSCP which was why I was facing this problem. Now I'm good with connecting to SFTP.
Thanks for your reply
Sudhir
