Topic "Exclude file listing from log file"
philcart
Hi
I was wondering if there is an option to exclude writing each individual filename to the log when synchronising a directory.
We're dealing with an external provider that generates 100's of files, and they archive very rarely. So when we run the sychronise the are 100's and 1,000's of files listed in the log file (see attached example).
Some of these log files are starting to get to multiple MB's in size and we'd like to trim them down a bit if possible.
Cheers
Phil
SecureTransfer_Powershell.txt (3.15 KB) [Download]
Description: Powershell Transfer Script
WinSCP_201411051710.txt (132.38 KB) [Download]
Description: Log File
There's no option for that.
philcart
Thanks Martin
Is that something that could be put on the feature list? Maybe an extra logging level.
Cheers
Phil
Let's see if more people ask for this.
Did you consider using XML logging?
http://winscp.net/eng/docs/logging_xml
