Topic "Parameter with spaces not parsed properly"
Rajesh.R
Please refer the screen shot.What's going wrong here? I have enclosed the directory path for lcd command with double double-quotes to make sure the spaces in the path are picked up while parsing.
Note: I am using winscp version 4.0.x
Description: screen shot
Pasting the error below in text for those who have problems viewing the screenshot -
Microsoft Windows XP [Version 5.1.2600]
(C) Copyright 1985-2001 Microsoft Corp.
U:\>"C:\Program Files\WinSCP\winSCP" /command "option batch on" "option confirm
off" "open test_user_2:xxxxxxxx@10.38.xxx.xx:5115" "cd /RCU/outbox" "lcd ""D:
\Documents and Settings\"""
batch on
confirm off
Searching for host...
Connecting to host...
Authenticating...
Using username "test_user_2".
Authenticated.
Starting the session...
Reading remote directory...
Session started.
Active session: [1] test_user_2@10.38.xxx.xx
/RCU/outbox
Too many parameters for command 'lcd'.
winscp> exit
U:\>
Double-double quotes are indeed not supported by 4.0.x.
See
http://winscp.net/tracker/show_bug.cgi?id=454
http://winscp.net/tracker/show_bug.cgi?id=494
You really need to upgrade (for many reasons).
See
Thanks for the reply. I am sorry... My version is actually 4.1.0. Will that be enough?
No. And you should absolutely not use such an old version in any case.
