Topic "rssh"
ixcesal
I use rssh shell. It makes, that user can't login to shell, only scp or sftp works.
The problem is winscp can't connect to rssh.
Anybody know how fix this problem?
ok, I found solution, rssh will be not work with WinSCP, but scponly shell works good.
rssh should work with WinSCP if you select SFTP protocol, not SCP. See rssh F.A.Q.
ixcesal
Yep, but I can't use sftp, so rssh can't be used with WinSCP.
Why you cannot use SFTP?
