Topic "Cannot login as root to Synology NAS Diskstation 5.1"
SimonOwl
Winscp 515 and 562
Win 8.1
Protocol: SCP
GUI, with either interface style
Trying to login as root to Synology NAS, after the upgrade to Diskstation 5.1
Errors: Host is not communicating for more than 15 seconds; after aborting: Error skipping startup message. Your shell is probably incompatible with the application (BASH is recommended).
"Optimize connection buffer size" has no effect
Changing shell from default has no effect
Note: Putty with SSH continues to work with 5.1, SCP worked with Diskstation 5.0 and stopped with 5.1
Logs attached
Logs.zip (5.64 KB) [Download]
Description: logs with default shell and Bash
fracer2
Confirming above problem when updating from Synology DSM 5.0 to 5.1, this morning. Partial log (tail):
Using username "joeper".
Prompt (7, SSH password, , &Password: )
Sent password
Access granted
Opening session as main channel
Opened main channel
Started a shell/command
Using SCP protocol.
Doing startup conversation with host.
Skipping host startup message (if any).
echo "WinSCP: this is end-of-file:0"
Waiting for data timed out, asking user what to do.
Asking user:
**Host is not communicating for 15 seconds.
fracer2
Change shell setting in WinSCP to "/bin/ash" (NOT "/bin/bash"). If you continue to have trouble, try also changing permissions on busybox: chmod 04755 /bin/busybox. Regards.
SimonOwl
Changing the shell to /bin/ash resolved the problem.
Thanks for your help, fracer2
Thanks for sharing your resolution.
Rim144
I have just tried to login to my synology nas after seeing the lights on continuously. I'm using Syno dos on the iPad but it is stating "your account has been disabled, contact your administrator" please help.
