Topic "Help with Script."
vsaga
Hello-
I have a csv file that I need to upload to a vendor. Below is the script; can't figure out why the code does not work; vendor says csv file has not been uploaded.
# Automatically abort script on errors
option batch abort
# Connect to SFTP server using a password
open sftp://User:Password@abc.com/
# Upload file
put C:\MyAccess\ss.csv /FTPDATA/User/
# Disconnect
I am using the following batch file to execute the above script.
@echo off
winscp.com /script="c:\MyAccess\MyAccessScriptFile.txt"
Any help would be appreciated!!
Thanks.
Your code look ok.
