Topic "Issue while Copying from Windows to Linux through script"
mahendra_sharma
I am using below script to copy from Linux to windows to copy XML files and its working perfectly fine although when i want to do the same copy from Windows to linux it doesnt work.
open sftp://username:password@linux server address -hostkey=""
option echo on
option batch on
option transfer binary
cd "/sasdata/prod/RCentre/HTML/"
lcd "C:\RC\Monit\HTML - Win7\"
get Cat.xml
get XML.xml
close
while copying from windows to linux, i am just changing lcd to cd and vice versa.
I used different options like get -resume or get -resumesupport. although nothing worked. Please help
To upload a file, you need to use put:
http://winscp.net/eng/docs/scriptcommand_put
On the other hand the cd and lcd should stay the same.
