Topic "If statement not working properly when STAT command executes"
Hi
I am using below code to check the whether file transferred properly and file exist by using STAT command. Infact the if the STAT command fails it should go to a case statement ERROR and execute the content of that case statement. But it is not reading the error case statement properly.
WinSCP /command "option batch continue" "option confirm off" "open HPAY_UAT" "lcd C:\Users\a160559\Desktop\DSC_TRANS\FILES\" "cd /data/dsc_files/" "put COMP_UPDATE.log /data/dsc_files/COMP_UPDATE.log" "stat /data/dsc_files/COMP_UPDATE.log" "exit"
if %ERRORLEVEL% neq 0 goto error
echo Error or file /data/dsc_files/COMP_UPDATE.log exists
exit 0
:error
echo Error or file /data/dsc_files/COMP_UPDATE.log not exists
exit 1
) > C:\Users\a160559\Desktop\Stat_out_exec_1.log
> Infact the above code is not going to case statement error when the file doesnt exist or the file transfer fails. Is there some other way to catch the Error Code: 2 to some variable.
> I would like to know whats exact the exit 0 and exit 1 does in this code. I tried the below code too.
if %ERRORLEVEL% neq 0 (
goto end
goto end
:end
echo finished
) > C:\Users\a160559\Desktop\Stat_out_exec_3.log
output was :
Can't get attributes of file '/data/dsc_files/COMP_UPDATE.log'.
No such file or directory.
Error code: 2
Error message from server: No such file
Request code: 7
Here it is not catching the exception at all.
It would be great if someone look into the code.
Hi
Can I get an quick reply regarding this issue.
SHIYAS M
It would be great if someone reply to this issue, so that I can close the development as soon as possible.
SHIYAS M
I'm not an expert in Windows batch files, but apparently the %ERRORLEVEL% in a block wrapped in brackets is resolved before that block starts. So it never reflects WinSCP exit code.
If you remove the brackets, it works:
exit 0
:error
exit 1
You can wrap your batch file to another batch file and do output redirection there.
Or if you need the brackets, use plain old if errorlevel 1:
if errorlevel 1 goto error
exit 0
:error
exit 1
Thanks a lot. It worked.
I am having a point to clarify. Whats the difference between exit 0 and exit 1. From googling I found that exit 0 will totaly come out of the code. But what is exit 1.
SHIYAS M
The exit command stops the script. If you specify an exit code as its argument, it returns that code to a parent process. An exit without an argument is equivalent to an exit 0.
