Topic "Cancelling a large upload not working"
isvaljek
Cancelling a large upload does not really work. Try to upload a file that takes longer than 20 seconds, and try to cancel it. Tested on many servers, the progress window goes unresponsive and I have to terminate the process.
Using WinSCP 5.5.6 4746 portable (zip) on Windows 8.1 Enterprise.
What protocol?
chingching
I'm thinking the OP might be just a casual user of WInscp, like myself, I'm not really interested in making a log,and posting it, and finding out what protocols i'm using. To me the most helpful answer would be either "Yes it's a bug", or "Nope it works on my computer". Since an admin answered the question, that should be easy to make that determination. If I know it's a bug I have no further worries. If it is my computer I can choose to work around the bug, or spend a long time trying to pinpoint the problem. For the occasional time I might have to cancel a big file update, ctrl-alt-delete is a lot faster than logging everything and posting.
Anyway for me, cancelling a big file upload does hang the program. Win 7, ftp with explicit encryption, I post this bc it helps other users know that the problem exists, if they encounter it.
Pathduck
To cancel in-progress downloads you need to use SFTP. It does not work with SCP. Also SFTP is a lot faster.
chingching
I am using FTP with explicit encryption. I was not using SCP. Do you also think cancel-in-progress does not work with FTP?
tempuser
42 Mb file, tried canceling after about 1/4 the way done. Won't cancel, have to kill task.
What protocol? What version of WinSCP? Please attach a full log file showing the problem (using the latest version of WinSCP).
lukinhasb
It happens to me as well. FTP with no encryption. Latest WinSCP version.
