Topic "WinSCP 5.5.6 crash when remote panel autoupdate is selected."
kmaint
All program info is in debuglog-file, level 2 selected.
What is done:
Setting is selected:
Option -> Preferences -> Panels -> Remote -> "Refresh remote panel every": 10
Opened normal ftp connection, e.g "ftp.funet.fi
cd to "/dev"
drag&drop "1Gnull" to any local folder.
After few seconds, WinSCP halt. And windows crash message, although in Finnish, i include it still here:
WinSCP stopped responding.
[Window Title]
WinSCP: SFTP, FTP and SCP client
[Main Instruction]
WinSCP: SFTP, FTP and SCP client stopped renponding.
Ongelman tunniste:
Ongelmatapahtuman nimi: APPCRASH
Sovelluksen nimi: WinSCP.exe
Sovelluksen versio: 5.5.6.4746
Sovelluksen aikaleima: 00000000
Vikamoduulin nimi: WinSCP.exe
Vikamoduulin versio: 5.5.6.4746
Vikamoduulin aikaleima: 00000000
Poikkeuskoodi: c0000005
Poikkeuksen poikkeama: 002bd8be
Käyttöjärjestelmän versio: 6.1.7601.2.1.0.256.48
Aluekohtaisten asetusten tunnus: 1035
Lisätietoja 1: 0610
Lisätietoja 2: 06107b45b2c44bc159ef4f2e3648f506
Lisätietoja 3: 2437
Lisätietoja 4: 24375100965cddb55a453867158e0743
<--- MESSAGE CUT---, no info anymore>
Tested with many servers, local network and remote. Always happen when option selected. Transfer work if selection is NOT selected.
Update time doesn't matter, as long "autoupdate" happens during transfer.
Remote filename doesn't matter, only seems that "autoupdate" while transfer is on, it causes crashing. Tested multiple times, and always happens.
When autoupdate is NOT selected, transfer is OK, and no program crash.
Tested on WinXP SP3 and WIndows 7, FI-locale. With ALL latest updates on every system.
winscp.log.second_server.log (550.46 KB) Private file
Description: (none)
winscp.log (648.9 KB) Private file
Description: WinSCP log file
http://winscp.net/tracker/show_bug.cgi?id=1253
I have sent you an email with a development version of WinSCP for testing to address you have used to register on this forum.
kmaint
Can't see email. Maby Google blocked it (EXE), or something else happened ?
Maby you can give direct link from where i can download file?
I have responded to your email.
