Topic "Updated client now I can't connect"
My server required a fresh install of the OS, the old HDD I used a private putty key. I also run winSCP at two different locations, At home I deleted old data when I uninstalled winSCP 4.4 from my PC and I was able to connect to my server with no issues. At work I didn't delete the data when I uninstall winSCP 4.4 and when then installed winSCP 5.56 and tried to connect making new profile but it didn't work out. I have uninstalled winSCP 5.56 and removed data that time but still will not let me connect. I took my server to work to figure this out and at work if I change the host from a URL to an local IP it will let me connect. I need the work one to be able to connect via internet. My guess the problem has something to do with that private putty key I used in winSCP 4.4. From lots of reading I believe my issues is cause I used a putty key and I forgot the pass phrase so I can 't reload it, how do I delete it off my server so I can connect again.
