Topic "Filemask problem"
buho
I am using a file mask as such Rate.txt; Address.txt; Help.txt; | */
with a remoteDirectory like /rt/my/no/yours/test/
I am using GetFiles method.
When I run the code none of the files are found, even though files exist for the filemask, if I remove the "*/" I get the "test" folder created and any sub directories in the test folder. All I want is the match .txt files.
What am I doing wrong?
thanks
Buho
Please share your code and session log file.
buho
You can see in the log file below that it is ignoring my "test" folder, this is the folder I want to read from.
In the FileMask: I thought adding " | */" would make it ignore all child sub directories, but it seems to apply to the top Directory "Test". Thanks for help with this.
Part of Log file:
2015-01-05 13:32:35.692 Script: get -nopermissions -preservetime -transfer="automatic" -filemask="User.txt; Address.txt; LSTEmployer.txt; LSTEmpAddr.txt; Cost.txt; Rate.txt; LSTRate.txt; LSTCost.txt; Quest.txt; | */" -- "/rt/bigbird/eit/sql/test/" "C:\Temp\SFTP_ProgressTests\HAB\Efile_SQL\*"
. 2015-01-05 13:32:35.702 Listing file "/rt/bigbird/eit/sql/test/".
> 2015-01-05 13:32:35.704 Type: SSH_FXP_LSTAT, Size: 34, Number: 263
< 2015-01-05 13:32:35.709 Type: SSH_FXP_ATTRS, Size: 37, Number: 263
. 2015-01-05 13:32:35.710 ;D;1024;2014-12-30T17:15:25.000Z;"" [0];"" [3];rwxrwxrwx;1
. 2015-01-05 13:32:35.711 File "/rt/bigbird/eit/sql/test/" excluded from transfer
* 2015-01-05 13:32:35.712 (EScpSkipFile)
> 2015-01-05 13:32:36.652 Script: exit
. 2015-01-05 13:32:36.653 Script: Exit code: 0
. 2015-01-05 13:32:36.654 Closing connection.
. 2015-01-05 13:32:36.654 Sending special code: 12
. 2015-01-05 13:32:36.655 Sent EOF message
My code: C#
public void SFTP_GetFiles() {
try {
SessionOptions sessionOptions = null;
getSessionOptions(_ftpServer, _userName, _password,ref sessionOptions);
using (Session session = new Session()) {
// Connect
session.ExecutablePath = _WinScpExec_Path;
session.SessionLogPath = @"\\<blah>\WorkingFiles\WinSCP\log123.txt";
session.Open(sessionOptions);
// download files
TransferOptions transferOptions = new TransferOptions();
transferOptions.FileMask = _fileList;
transferOptions.TransferMode = (TransferMode)Enum.Parse(typeof(TransferMode), _fileTransferMode_Ascii_Binary_Automatic, true); ;
_dtFtpStart = DateTime.Now;
//chained error throw
session.GetFiles(_remotePath, _localPath, _bDeleteFilefromServer, transferOptions).Check();
catch (Exception ex) {
throw new Exception("BOS.Shared.WinScp_SFTP method: SFTP_GetFiles failed: " + _ftpServer + " " + ex.Message);
You have to use /rt/bigbird/eit/sql/test/* to tell WinSCP to download contents of the test folder, not the folder itself (that gets excluded by the mask).
