Topic ""sessionOptions.SshPrivateKeyPassphrase" not working!"
I was made to understand that having installed the latest beta version "" of "WinSCPnet.dll" namely this version:, you could use the above sessionOptions variable to pass on the Passphrase of your private key. Well, i've done all that but it doesn't seem to work. I keep getting this response: "Disconnected: No supported authentication methods available (server sent: publickey)". Now my question please if some one could help? I urgently need a working example of any powershell script that uses this parameter. Thanks in advance. By the way, thumbs up for this great piece of work. The Author deserves all the applause and respect.
