Topic "Unknown -passphrase switch in open command."
Nicolas.Tsamis
I am using the latest version of WinSCP 5.5.6 but I still have problem for the -passphrase switch to be recognized when using the open command. My scripting line is as follows and when I omit the passphrase switch and entering it manually everything works Ok. When I use the switch I get an error message "Unknown Switch". Documentation mentions that this is a feature of the latest version. Is 5.5.6 the latest version?
open sftp://secretboutique:secretboutique@secretboutique.gr/ -privatekey="C:\Bitway.ppk" -passphrase="xxxxx"
Please advise
Best Regards
Nicolas
The 5.5.6 is the latest stable version. The -passphrase is supported in the latest BETA version only.
See http://winscp.net/tracker/show_bug.cgi?id=816
Maxim
Is it possible to hide passphrase from log session events?
. 2015-01-26 18:32:00.384 --------------------------------------------------------------------------
. 2015-01-26 18:32:00.384 Script: Retrospectively logging previous script records:
> 2015-01-26 18:32:00.384 Script: option batch on
< 2015-01-26 18:32:00.384 Script: batch           on
< 2015-01-26 18:32:00.384 Script: reconnecttime   120
> 2015-01-26 18:32:00.384 Script: option confirm off
< 2015-01-26 18:32:00.384 Script: confirm         off
> 2015-01-26 18:32:00.384 Script: option reconnecttime 120
> 2015-01-26 18:32:00.384 Script: open "sftp://user@localhost:22" -hostkey="ssh-rsa 2048 aa:ss:dd:ff:gg:hh:ii:oo:ii:uu:yy:tt:rr:ee:ww:qq" -privatekey="key.ppk" -passphrase="Plain text" -timeout=15
-passphrase="**********"
Best Regards
Maxim
Thanks for the suggestion. Will try.
This request has been added to the tracker:
http://winscp.net/tracker/show_bug.cgi?id=1277
Rubble
When I use the -passphrase switch from the command line, it is not passed and I am still prompted to enter the passphrase manually. Any ideas?
winscp.com /command "open sftp://<username>@<host>.com/ -privatekey="C:\temp\ABC-TEST-Upload-PrivKey.ppk" -passphrase="<mypassphrase>"
! 2016-04-13 16:22:09.580 Authenticating with public key "rsa-key-1111111"
. 2016-04-13 16:22:09.580 Prompt (passphrase, "SSH key passphrase", <no instructions>, "Passphrase for key "rsa-key-1111111": ")
. 2016-04-13 16:22:19.589 Disconnected: Unable to authenticate
I'm using 5.7.7.
Your syntax is wrong.
It should be:
winscp.com /command "open sftp://<username>@<host>.com/ -privatekey=""C:\temp\ABC-TEST-Upload-PrivKey.ppk"" -passphrase=""<mypassphrase>"""
See http://winscp.net/eng/docs/commandline#syntax
