Topic "Automatically "Keep remote directory up to date""
blahblah8192
I have a shortcut on my desktop that connects my FTP server.
Is it possible that when I double click on this shortcut :
(See attachment 1 below)
the feature "Keep remote directory up to date" is automatically started:
(See attachment 2 below)
* without having to do "CTRL+U"
* without having to click "Start"
* without having to click No on the popup "Do you want to synchronize?"
winscp (2).jpg (51.37 KB)
Description: (none)
winscp (1).jpg (6.21 KB)
Description: (none)
Use /keepuptodate command-line parameter (remove /uploadifany if there's one).
See http://winscp.net/eng/docs/commandline
Add /defaults command-line parameter.
Just check (or uncheck, depending on your preferences) the Synchronize on start checkbox and check Use same options the next time.
Also note that the function "Keep remote directory up to date" has been improved in 5.6.x. Consider upgrading.
