Topic "Remove leading path from source files (getfiles, multi-file)"
a1
This Powershell code is used to download all files from the remove server's "/In" directory.
# Powershell
Add-Type -Path "C:\Program Files (x86)\WinSCP\WinSCPnet.dll"
$remotePath = "/In";
$localPath = "D:\temp";
$removeRemote = $TRUE;
$transferResult = $session.getfiles($remotePath, $localPath, $removeRemote);
It saves files in "D:\temp\In", but I want the files to be saved in "D:\temp". How do I remove the leading "In" part of the source file names?
WinSCP 5.5.6 (build 4746).
Using /In tells WinSCP to download the folder, not its contents only. Use /In/*.
Also using D:\temp seems wrong and it should not do what you describe. You should use D:\temp\.
a1
Thank you very much. It works perfectly.
