Topic "powershell session.FileExists($remotePath) foreach"
unimog
So I've tested the generic code of $session.FileExists($remotePath) which works great but as soon as I put the statement within a foreach loop it keeps telling me file doesn't exists. Anyone have experience or a solution to the problem I'm having?
try
    # Load WinSCP .NET assembly
    Add-Type -Path "C:\winscp\WinSCPnet.dll"
    # Setup session options
    $sessionOptions.Protocol = [WinSCP.Protocol]::Sftp
    $sessionOptions.HostName = "server01"
    $sessionOptions.UserName = "user"
    $sessionOptions.Password = "user1"
    $sessionOptions.SshHostKeyFingerprint = "ssh-rsa 2048 xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx"
    try
        # Connect
        $programFileNameList = Get-Content D:\program\programFileName.lst
        #Program List Error Check
        foreach( $programFileName in $programFileNameList )
            Write-Host ("name: $programFileName")
            $remotePath = "/home/user/utility/Program/$programFileName"
            #$remotePath = "/home/user/utility/Program/program2.csv"
            Write-Host ("searching: $remotePath")
            if($session.FileExists($remotePath))
                Write-Host ("File {0} exists" -f $remotePath)
            else
                Write-Host ("File {0} does not exist" -f $remotePath)
    finally
        # Disconnect, clean up
        $session.Dispose()
    exit 0
catch [Exception]
    Write-Host $_.Exception.Message
    exit 1
unimog
file attached
psftp.log (8.89 KB) Private file
Description: (none)
There's a space at the end of every file path.
        v
> 2015-01-06 11:14:13.026 Script: stat -- "/xjp/utility/CapEx/Program/program2.csv "
