Topic "Changing local directory from one session changes it for all"
EBuissonnet
With GUI version in commander mode of WinSCP 5.6.4.4913
running on Windows 7 64 bits
When changing the local directory of one session, it is also change for all other not related sessions.
This problem affects the local directory, not the remote directory
Any mean to change local directory (Home directory button, click on .. icon, ctrl-H shortcut) has the same effect.
I am not supposed to have activated any particular fancy option, except by unticking the "Remember last used directory" checkbox
Thanks for any help
I assume you are looking for a local panel option Do not change state when switching sessions:
http://winscp.net/eng/docs/ui_pref_panels_local
EBuissonnet
Yes, sorry. I clearly misunderstood the role of this checkbox.
