Topic "get command with -filemask"
joesyuh
I am attempting to download the last modified file in the past two days that starts with the letter "H". This is my current script. I am getting the error
Quote:
Missing Parameter for command 'get'
This is my script
option batch continue
open hart
get -filemask="*>=2D ; H*" ./
At the moment I just want it to download to the current working directory.
Your command is correct. Supposing you are using some reasonably recent version of WinSCP.
