Topic "consolidate or discard folders"
Kurbycar32
I am synchronizing from a server using a txt script. The server contains many directories, and I do not need the folders, just the files inside. Is there a way to download only the contents of those folders without recreating the directory structure? I realize that a sync probably wont do the job anymore and I am open to change. Maybe I can use a search that includes subfolders and then download those results, but I was unable to determine the syntax from the page I found on that subject: http://winscp.net/eng/docs/custom_commands#search. I also searched the forum before posting
kurbycar32
anybody
You cannot do this using simple scripting.
But this could be easy using WinSCP .NET assembly.
This example shows how to recurse:
http://winscp.net/eng/docs/library_example_recursive_search_text
It actually even downloads all the files the one folder (temp folder in this case). So it just needs few tweeks to do what you need.
