Topic "Synchronize file type in order - help needed"
malva
Hi!
I'm synchronizing directories and all works fine but I need help.
I would like to download (synchronize) first all files that are NOT .xml and then download remaining .xml files.
Anybody could help me. Please.
m.
    Try
        # Connect
        $localPath = "E:\test\import"
        $remotePath = "/"
        # Synchronize files to local directory, collect results
        $synchronizationResult = $session.SynchronizeDirectories(
            [WinSCP.SynchronizationMode]::Local, $localPath, $remotePath, $False, $False, [WinSCP.SynchronizationCriteria]::Time, $transferOptions)
        foreach ($download in $synchronizationResult.Downloads)
            # Success or error?
            if ($download.Error -eq $Null)
                Write-Host ("Download of {0} succeeded, removing from source" -f
                    $download.FileName)
                # Download succeeded, remove file from source
                $removalResult = $session.RemoveFiles($session.EscapeFileMask($download.FileName))
                if ($removalResult.IsSuccess)
                    Write-Host ("Removing of file {0} succeeded" -f
                        $download.FileName)
                else
                    Write-Host ("Removing of file {0} failed" -f
                        $download.FileName)
            else
                Write-Host ("Download of {0} failed: {1}" -f
                    $download.FileName, $download.Error.Message)
    finally
        # Disconnect, clean up
        $session.Dispose()
    exit 0
catch [Exception]
    Write-Host $_.Exception.Message
    exit 1
Use include file mask *.xml for the first step and exclude file mask |.xml for the second step.
See http://winscp.net/eng/docs/file_mask
