Topic ".NET integration Exception throw Host key does not match"
gvarini
Hi.
I need to send a file throw sftp with private/public keys. Both were generated with putty. Every time i try to open session i get the same exception.
What i dont understand is if this is an error cause by the keys or not. And if in the catch i can make a workaround.
try
//Send Ftp Files - same idea as above - try...catch and try to repeat this code
//if you can't connect the first time, timeout after a certain number of tries.
Protocol = Protocol.Sftp,
HostName = "xxx.xxx.xxx.xxx",
UserName = "user",
PortNumber = 22,
SshHostKeyFingerprint = "ssh-rsa 2048 xx:xx:xMadx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx",
var session = new Session();
session.SessionLogPath = ConfigurationManager.AppSettings["BatchPath"] + @"\log.txt";
//session.ExecutablePath = "";
session.Open(sessionOptions); //Attempts to connect to your sFtp site
//Get Ftp File
TransferOptions transferOptions = new TransferOptions();
transferOptions.TransferMode = TransferMode.Binary; //The Transfer Mode -
//<em style="font-size: 9pt;">Automatic, Binary, or Ascii
transferOptions.FilePermissions = null; //Permissions applied to remote files;
//null for default permissions. Can set user,
//Group, or other Read/Write/Execute permissions.
transferOptions.PreserveTimestamp = false; //Set last write time of
//destination file to that of source file - basically change the timestamp
//to match destination and source files.
transferOptions.ResumeSupport.State = TransferResumeSupportState.Off;
//the parameter list is: local Path, Remote Path, Delete source file?, transfer Options
var transferResult = session.PutFiles(filePath, "", false, transferOptions);
//Throw on any error
transferResult.Check();
//Log information and break out if necessary
catch (Exception exception)
throw exception;
Logs:
Host key does not match configured key ssh-rsa 2048 05:3d:0f:62:5d:8d:06:eb:d4:03:1f:49:4f:16:a7:81
. 2015-01-29 09:42:04.868 Asking user:
. 2015-01-29 09:42:04.868 **Continue connecting to an unknown server and add its host key to a cache?**
. 2015-01-29 09:42:04.868 The server's host key was not found in the cache. You have no guarantee that the server is the computer you think it is.
. 2015-01-29 09:42:04.868 The server's rsa2 key fingerprint is:
. 2015-01-29 09:42:04.868 ssh-rsa 2048 53:a2:4c:2c:22:6a:17:17:37:67:d7:2d:23:7e:86:f1
. 2015-01-29 09:42:04.869 If you trust this host, press Yes. To connect without adding host key to the cache, press No. To abandon the connection press Cancel. ()
. 2015-01-29 09:42:04.869 Attempt to close connection due to fatal exception:
* 2015-01-29 09:42:04.869 Host key fingerprint is ssh-rsa 2048 53:a2:4c:2c:22:6a:17:17:37:67:d7:2d:23:7e:86:f1.
* 2015-01-29 09:42:04.869 (Exception) **Host key wasn't verified!**
. 2015-01-29 09:42:04.869 Closing connection.
. 2015-01-29 09:42:04.869 Sending special code: 12
The server's public key fingerprint that you set to SessionOptions.SshHostKeyFingerprint (ssh-rsa 2048 05:3d:0f:62:5d:8d:06:eb:d4:03:1f:49:4f:16:a7:81) does not match actual server's public key (ssh-rsa 2048 53:a2:4c:2c:22:6a:17:17:37:67:d7:2d:23:7e:86:f1).
See http://winscp.net/eng/docs/ssh_verifying_the_host_key
gvarini
Thx prikryl for the response.
From the link u gave me, "However, when you connect to a server for the first time, WinSCP has no way of telling whether the host key is the right one or not."
So the first time i try to open session i will always get the exception? In that case i should set GiveUpSecurityAndAcceptAnySshHostKey = TRUE ?
This may happens if on the other sidth (client) i have a proxy making a redirect?
Regards.
That's for GUI.
With .NET assembly, you tell WinSCP explicitly, what host key you expect using the .SshHostKeyFingerprint.
