Topic "end of file - special code 12"
stevlyo
WinSCP Version 5.5.4 (Build 4433) (OS 6.1.7601 Service Pack 1 - Windows Server 2008 R2 Standard)
2015-01-29 16:10:06.291 Using SCP protocol.
. 2015-01-29 16:10:06.292 Doing startup conversation with host.
! 2015-01-29 16:10:06.292 stty: standard input: Invalid argument
. 2015-01-29 16:10:06.345 Skipping host startup message (if any).
> 2015-01-29 16:10:06.345 echo "WinSCP: this is end-of-file:0"
< 2015-01-29 16:10:06.409 WinSCP: this is end-of-file:0
. 2015-01-29 16:10:06.409 Detecting variable containing return code of last command.
. 2015-01-29 16:10:06.409 Trying "$status".
> 2015-01-29 16:10:06.409 echo "$status" ; echo "WinSCP: this is end-of-file:0"
< 2015-01-29 16:10:06.448 $status
< 2015-01-29 16:10:06.488 WinSCP: this is end-of-file:0
. 2015-01-29 16:10:06.488 The response is not numerical exit code
. 2015-01-29 16:10:06.488 Trying "$?".
> 2015-01-29 16:10:06.488 echo "$?" ; echo "WinSCP: this is end-of-file:0"
< 2015-01-29 16:10:06.538 $?
< 2015-01-29 16:10:06.580 WinSCP: this is end-of-file:0
. 2015-01-29 16:10:06.580 The response is not numerical exit code
. 2015-01-29 16:10:06.581 Attempt to close connection due to fatal exception:
* 2015-01-29 16:10:06.581 (ECommand) Error detecting variable containing return code of last command.
. 2015-01-29 16:10:06.581 Closing connection.
. 2015-01-29 16:10:06.581 Sending special code: 12
. 2015-01-29 16:10:06.581 Sent EOF message
* 2015-01-29 16:10:06.613 (EFatal) Error detecting variable containing return code of last command.
What kind of a server that is?
WinSCP has very specific requirements on the server with SCP protocol:
http://winscp.net/eng/docs/requirements#scp
The windows server is: (OS 6.1.7601 Service Pack 1 - Windows Server 2008 R2 Standard
The target system is a Cisco 9148 SAN Switch.
I'm afraid your server is probably not compatible with WinSCP. Does it support SFTP?
For details on "Sending special code: 12", see
http://winscp.net/eng/docs/message_special_code
