Topic "Warning message."
After updating to versions 3.6.6 and 3.6.7, I get this warning message window when trying to connect:
WinSCP3.exe - No Disk
There is no disk in the drive. Please insert a disk into drive \Device\Harddisk1\DR1.
There are also three push buttons labeled:
Cancel, Try Again, and Continue.
Everything then works fine if I select Cancel or Continue. Do you know what the problem could be?
Please follow to this topic.
Can you check for me, in what version of WinSCP the problem was introduced? You may download the older versions on Sourceforge.
The version that the problem was introduced is 3.6.5 beta. Version 3.6.1 does not have the problem.
Can you please duble check this. Someone in the other post says that the problem was not present in 3.6.5 beta yet.
I double checked this, and verified that I start seeing the problem with version 3.6.5 beta. I am running Windows XP Professional Version 2002 Service Pack 1.
Another one has confirmed me that the problem was introduced in 3.6.6. I'm quite confused Sad
Anyway, can anyone download debug version of WinSCP?
It produces trace log to file defined by WINSCPTRACE environment variable.
You may use .bat file like following to run it. Just modify it to point to writeable location on your system.:
set WINSCPTRACE=c:\winscptrace.log
winscp3.exe
Update: I've forgot one important thing: I need the copy of the file in the time when the error message appears. I.e. let the error show and make the copy of the file, before you press any button and send me the copy.
Update2: Version with more verbose tracing was uploaded. The link above has been updated to point to the new version.
Update3: Another update of the tracing.
Here is the winscptrace.log file:
[7:54:48 AM] WinMain.cpp:421:Execute
Execute
[7:54:48 AM] WinMain.cpp:32:GetLoginData
GetLoginData
[7:54:51 AM] WinMain.cpp:106:GetLoginData
/GetLoginData
[7:54:51 AM] WinMain.cpp:509:Execute
Execute before connect
[7:54:53 AM] WinMain.cpp:512:Execute
Execute before connected
[7:54:53 AM] PAS:0:unk
TDirView
TDirView 1
/TDirView
TIEPathComboBox.Create
TIEPathComboBox.Create 1
TIEPathComboBox.Create 2
TIEPathComboBox.Create 3
TIEPathComboBox.Create 4
/TIEPathComboBox.Create
TDriveView.Create
TDriveView.Create 1
/TDriveView.Create
TDriveView.CreateWnd
TDriveView.CreateWnd 1
/TDriveView.CreateWnd
TDriveView.Loaded
TDriveView.Loaded 1
TDriveView.RefreshRootNodes
TDriveView.RefreshRootNodes drive A
TDriveView.RefreshRootNodes flags 12 C
TDriveView.RefreshRootNodes read drives 1
ReadDriveStatus
ReadDriveStatus 1
ReadDriveStatus 2
ReadDriveStatus 3
ReadDriveStatus 4
[7:54:54 AM] PAS:0:unk
ReadDriveStatus 5
ReadDriveStatus 8
ReadDriveStatus 9
ReadDriveStatus 10
ReadDriveStatus 11
ReadDriveStatus 12
ReadDriveStatus 13
ReadDriveStatus 15
/ReadDriveStatus
TDriveView.RefreshRootNodes valid 1
TDriveView.RefreshRootNodes pidl 0, init 1, ready 0, type 2, name "3 Floppy (ASmile"
TDriveView.RefreshRootNodes pretty name "A: 3 Floppy ", serial "0", size -1, image 0, fs "", flags 0
TDriveView.RefreshRootNodes 1
TDriveView.RefreshRootNodes 2
TDriveView.RefreshRootNodes 3
TDriveView.RefreshRootNodes 4
TDriveView.RefreshRootNodes 5
TDriveView.RefreshRootNodes 6
TDriveView.RefreshRootNodes 9
TDriveView.RefreshRootNodes 10
TDriveView.RefreshRootNodes 11
TDriveView.RefreshRootNodes drive B
ReadDriveStatus
ReadDriveStatus 1
ReadDriveStatus 2
ReadDriveStatus 3
/ReadDriveStatus
TDriveView.RefreshRootNodes valid 0
TDriveView.RefreshRootNodes pidl 0, init 1, ready 0, type 1, name ""
TDriveView.RefreshRootNodes pretty name "", serial "0", size 0, image 0, fs "", flags 0
TDriveView.RefreshRootNodes drive C
ReadDriveStatus
ReadDriveStatus 1
ReadDriveStatus 2
ReadDriveStatus 3
ReadDriveStatus 4
ReadDriveStatus 5
ReadDriveStatus 8
ReadDriveStatus 9
ReadDriveStatus 10
ReadDriveStatus 11
ReadDriveStatus 12
ReadDriveStatus 13
ReadDriveStatus 15
/ReadDriveStatus
TDriveView.RefreshRootNodes pidl 87F60, init 1, ready 0, type 3, name "Local Disk (CSmile"
TDriveView.RefreshRootNodes pretty name "C: Local Disk ", serial "0", size -1, image 0, fs "", flags 0
TDriveView.GetNodeShellAttr 1
TDriveView.GetNodeShellAttr 2
TDriveView.GetNodeShellAttr path "C:\"
TDriveView.GetNodeShellAttr pidl "0"
TDriveView.GetNodeShellAttr pidl "881E0"
TDriveView.GetNodeShellAttr 3
TDriveView.GetNodeShellAttr attr 800F0000
TDriveView.GetNodeShellAttr 4
TDriveView.GetNodeShellAttr attr 80000000
TDriveView.GetNodeShellAttr 5
TDriveView.GetNodeShellAttr 6
TDriveView.GetNodeShellAttr 7
/TDriveView.GetNodeShellAttr
TDriveView.RefreshRootNodes drive D
ReadDriveStatus
ReadDriveStatus 1
ReadDriveStatus 2
ReadDriveStatus 3
ReadDriveStatus 4
ReadDriveStatus 5
ReadDriveStatus 8
ReadDriveStatus 9
ReadDriveStatus 10
ReadDriveStatus 11
ReadDriveStatus 12
ReadDriveStatus 13
ReadDriveStatus 15
/ReadDriveStatus
TDriveView.RefreshRootNodes pidl 7A020, init 1, ready 0, type 2, name "Zip 250 (DSmile"
TDriveView.RefreshRootNodes pretty name "D: Zip 250 ", serial "0", size -1, image 0, fs "", flags 0
TDriveView.GetNodeShellAttr path "D:\"
Thanks.
Can someone try test version of WinSCP? Let me know if it fixes the problem.
Guest_
Yes, that seems to have fixed the problem. Thank you very much.
Thanks, that are good news. However I would like to see at least one more independent confirmation Smile
Update: There's final version without the tracing ability. I would like to have confirmed that it works as well.
Guest_
Yes, the final version works just fine. Thank you for fixing the problem.
I recently upgraded to WinSCP 3.7.1 (on Windows XP) and this problem is back. I have seen it in other software; and from the research I did at the time this is a result of an old windows API call to list drives and its interaction with removeable disk (Flash) drives (I have a USB Flash drive reader on my machine, always plugged in, fairly rarely with a disk in it; when there is a disk in it the error message does not appear - P.S. I get this message once per 'drive', as my USB reader shows up as 2 drives the error appears 2x.
There is no disk in the drive. Please insert a disk into drive \Device\Harddisk2\DR14.
Cancel Try Again Continue
Can you confirm that the problem is not present in 3.7 beta?
